Modern boat vs. Price
Simon Mac
Hello dudes and dudettes,
Wanted to open a discussion thread with regards to the purchase of a new boat.
I was thinking along the lines of jackson vs. Lettman vs. Liquidlogic (stomper) vs. Dagger(mamba) vs. Waka. I've paddled Zet and know enough about that.
Id like to have peoples opinions on a best boat for Alpine purpose, considering a cost vs. Function factor in mind.
Paddler weight: currently 70kg
Sent from my GT-I9300 using Tapatalk
Ultimate Grudgematch: Chuck Norris Vs. Chuck Norris
MikeShaw
Dont know enought about the other boats to comment but just FYI buy with getting fat in mind (you will)!!!
Working life has a way of creeping up on you!!!
If you go over 85kg though then you are a pig!!!
Think 10%-15% gain :)
"Isn't that Sexual Harrasment?"
"Not if you're Good Looking!"
mmmm_scandalous
Karnalli Lad.. My god.. What a brilliant boat!
I've read good reports on the Burn mk3, plus I'll have a Mk2 medium Burn for sale soon enough everything going to plan.
I'd suggest Stomper. Boofs like a machine, forgiving and still carves a bit. If you want something faster, carvier but less forgiving then Exo XT
That exo boat can behave oddly at high tilt angles with the channel behind the cockpit. Ask Keyes about that!
Conor_B
EoinK, how do you find the Exo when the boat is at a high tilt? Can it behave oddly?
A lot of truth is said in jest.....
AndrewRegan
Ive been in a lot of different boatsthis season. Bar the obvious statement that its all about the pilot over the boat.
These are my short impressions of the boats ive paddled:
MK III burn feels great, fast and carves very nicely, big improvement on the old burns. Very light, hopefully this has no bearing on the quality of the plastic.
JK Karma is nice, fast and light, really good design in my opinion. It also has this great feature where it seems to pick up speed very quickly. Don't like the outfitting despite its simplicity, too flimsy.
Mamba is a very nice boat especially with the contour outfitting, very stable, easy to manoevre, easy to boof even with no speed if I was to change anything it'd be to make the hull a bit more streamlined and faster for racing. Nomad: Same design for over 10 years and still a top seller, says it all really. Ideal boat for steep rocky rivers. They are heavier then other boats on the market but seem pretty robust, Ive not seen many on the operating table.
Ive only been in a stomper a couple of times, feels ok, but the hull is notoriously weak (bit like the jefe). The remix is an unbelievably fun and fast boat. Not sure about space for gear and stuff, but if your looking a good time get in this boat. REMIX REMIX REMIX :)
Waka definitely rides high over holes which is nice and it feels fast in the middle of rapids, I was constantly fighting it to go in a straight line in G2/G3 water though.
Recon... very slow and heavy boat, that said, its extremely stable and will get you through any hole upright.
Lettman: No opinion, havent paddled one.
Prices of them new are all pretty similar to be fair, and so are many of the designs.
For the Alps all I'll say is I'd prefer a bigger boat mainly because of the gear you'll have in the back. Its a shit feeling to have an overloaded creek boat.
Conor_B wrote:EoinK, how do you find the Exo when the boat is at a high tilt? Can it behave oddly?
If you plug through a hole while on a slight edge the contours at the side of the cockpit can grab water and direct it up over the back deck, which pulls the rail down deeper into the water. It can be quite agressive occasionally, if you're unlucky enough to go through the right (wrong?) hole with the wrong amount of edge.
Easy solution = boof feckin everything! While the boat's on the surface it handles great. I'm looking forward to getting it out on some solid rivers over in the Alps and really getting a feel for it. I've nearly forgotten what it's like to paddle now it's been so long!
Bekey
Regan is right you should have a go in a remix they are class! Great outfitting, feels really nice and does everything you want. Also think the raptor is class, but you already know that . .
Ethan
lettman is a very nice, fast creeker. It felt like a a slalom boat, its definitely woth getting a lend of one for a go
